Best way for forcing sharing between 2 series capacitors
Discussion in 'General Electronics Chat' started by karas, Oct 3, 2016.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    129
    What's the best way for forcing sharing between 2 series capacitors rather than add resistor in parallel with the capacitor. Another question if you have output of the power supply for example 10vdc and 1 a dc and switching frequency 60 kHz and ripple need to be less than or equal 1mv so what is the value of capacitance I need?
  2. #12
    Nov 30, 2010
    16,704
    7,354
    What is the best way besides the best way? I'm going to need to see the circuit.
    Post a schematic.
  3. SLK001
    Nov 29, 2011
    852
    243
    How would you share what goes thru two series capacitors? What do you mean by share? What goes thru one goes thru the other.
  4. karas
    Sep 8, 2011
    129
    is my question is stupid or what is the wrong in my question? or you do not like my English? or what is wrong?
  5. karas
    Sep 8, 2011
    129
    the voltage across the 2 capacitors is 800 vdc and each capacitor is 470uf and 450vdc , so I need to make sure that each capacitor has about 400vdc
  6. SLK001
    Nov 29, 2011
    852
    243
    If the two caps are the same value, then they will form a voltage divider with equal voltage drop across each.
  7. karas
    Sep 8, 2011
    129
    the cap. has 10% tolerance
  8. Brevor
    Apr 9, 2011
    282
    56
    The best way is to add the two resistors across the caps like you said. I dont know of any other way.
  9. ronv
    Nov 12, 2008
    3,403
    1,477
  10. SLK001
    Nov 29, 2011
    852
    243
    Then put one 15-20 watt 22kΩ resistor across each capacitor.
  11. karas
    Sep 8, 2011
    129
    I need to avoid the dissipation on the resistor .do you think if we but zener it will work or may be one conduct first and scroe the balance
