Best transistor switch for stepper motor
Discussion in 'Embedded Systems and Microcontrollers' started by Shorty, Apr 2, 2009.
  1. Shorty
    Apr 2, 2009
    Hi, experts!
    What is, in your opinion, the best transistor switch for this app?
    +12V
    LOAD----<-<-<-- Transistor Base----<-<-<---PIC output (max 10-20mA)
    (5-10A)
    (3-4 A may also work)
    GND
    The load is a stepper motor winding so of course i need 4 switches.
    I am looking at BD679 or BD649, but I'm, open for suggestions.
    I want a clean, simple circuit so darlington transistors are preferred.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We ask that posters not hijack existing threads by placing their questions in the existing flow. Especially when the thread is 2 years old - http://forum.allaboutcircuits.com/showthread.php?t=6168. It can be confusing as to which question is being replied to.
    Perhaps you might think of a current limiting resistor in the base circuit.
  3. Shorty
    Apr 2, 2009
    I am very sorry I did that. Can I move it to a new thread or post it again to a new thread?
    Anyway, yes, a resistor limits base current to 10mA.
    Transistor idea?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Which type of stepper?
    Sometimes an IC like the SN754410 (quad half H-Bridge driver, upgraded L293D) is a simpler solution for small steppers, for the currents you need, an IC driving the transistors also frees up some pins on the PIC.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    As has been pointed out already, you have failed to tell us which type of stepper motor you are using. This information goes to the heart of the solution you request.
    Knowing whether it is a bipolar or a unipolar will help us help you.
    hgmjr
  6. Shorty
    Apr 2, 2009
    Thanks ! :)
  7. gunaynail271
    Oct 4, 2006
    bdx53 or tip122
  8. atferrari
    Jan 6, 2004
    2,674
    785
    I did my first tests using small steppers and the 2N2222 was enough.
    With a Darlington transistor, your 10 mA base current could be much more than what you need. It all depends what stepper (thus what transistor) you use.
    Restating the obvious.
    Buena suerte.
