Best solution to get 3.3V from 5V-20V @ 250mA
Discussion in 'General Electronics Chat' started by tom66, Oct 8, 2010.
  1. tom66
    Thread Starter Senior Member
    May 9, 2009
    2,613
    214
    For my Super OSD project, I need a +3.3V supply at 250mA from a variable input of 5.5V to 20V. Cost is a concern, as is size. Originally, I considered an LM317 in a SOT-223 package, due to the small size. Unfortunately, it's difficult to get a heatsink for SOT-223 packages.
    Then I did some calculations; the LM317 would be dissipating up to 4.175W with 20V input and 250mA of load and with a θJA of 140°C/W, the LM317 would cook along nicely at 584°C above ambient. So not practical.
    The next solution would be a little buck converter, but I'm looking to get a small design and a cost of <$3. Does anyone know of an ideal chip for the job? Or is it still possible to use a linear regulator? I'd prefer to do so, but getting rid of the wasted heat is really a problem. Power efficiency is not critical for this application, as an electric motor will be drawing 10's of amps, compared to the few hundred mA for this module.
  2. Zez
    Apr 29, 2009
    Perhaps LM317 in TO-263 package would be the right solution.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Can you order at conrad?
    Then take a look at the part in the datasheet.
    Bertus
  4. tom66
    May 9, 2009
    2,613
    214
    @Zez: TO-263 would be an option, but it still has 50°C/W thermal resistance, and at 4.175W that would be 209°C above ambient.
    @Bertus: I don't really want to use a module, because it restricts me to a single source, and because they are quite big. Thanks for the link though.
  5. Kermit2
    Feb 5, 2010
    3,847
    963
