I was wondering about the best op-amp to use for a photo-diode in trans-impedance amplifier configuration. Is the trusty LM741 op amp good enough? I've been searching Google and i havn't had an answer in layman's terms that i can understand. At the moment i have an photo-diode amplifier , a LTC1050 set up in the configuration in the picture
And the circuit is working fine, would i be right in saying this is in photo-voltaic mode rather than photo-conductive mode?
Also the amplifier i have used has only a +5V supply, how can this work as i thought all op-amps need a split power supply +-5V.
