Best method for reverse polarity protection and without power loss?
Discussion in 'General Electronics Chat' started by Fuji, Dec 22, 2014.
  1. Fuji
    Nov 8, 2014
    100
    My power source is 9v for the entire circuit. As I undertand, the common way to prevent damages to a circuit would be to use a diode. Another method is a bridge rectifier However, I get voltage drops and lose power with a diode, and twice the loss of power with a bridge rectifier.
    Taking to consideration for voltage drops with circuit protection, my question is if there is a possible way to make a reverse polarity protection without any loss of power at all? Or will there always be losses of power no matter what for this type of feature in any circuit?
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    What device are you offering protection for?
    You could always increase the supply to compensate.
    A single diode the polarity has to be correct, with a bridge it does not matter.
    Max.
  3. Fuji
    Nov 8, 2014
    100
    Thanks for the reply. It is not a product that I bought. I am building a circuit myself that is powered with 9v. It hit my mind that I wanted to protect the circuits. Right after the power source of 9v, I have a buck booster. I thought maybe protection before the booster would be beneficial.
    So what your saying is, maybe increase the voltage by say...1.5volts, which then = to 10.5v just to compensate 9v? Sounds like a good idea.
    For 9v power, is a 1A diode or Schottky diode (I assume is better for lower voltage drop) good enough?
  4. crutschow
    Mar 14, 2008
    13,475
    3,361
    If you don't want to have to increase the supply voltage to compensate for a diode drop, here's a low forward-drop, reverse-protection circuit using a MOSFET.
    JohnInTX, bug13 and Fuji like this.
  5. ronv
    Nov 12, 2008
    3,393
    1,449
    Or NFET of the same circuit.
  6. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    The advantage of the bridge the circuit still operates with the wrong polarity applied.
    Max.
  7. LDC3
    Apr 27, 2013
    920
    160
    Yes, it would be difficult to get more than 0.5A from one 9V battery for any length of time.
  8. cmartinez
    Jan 17, 2007
    3,698
    2,757
    Crutschow's right, a p-mosfet is the best way to protect for reverse polarity with minimal power loss. Watch the explanation on this video.
  9. blocco a spirale
    Jun 18, 2008
    1,457
    369
    Diodes are often fitted in parallel with the supply and after the input fuse to protect against reverse supply polarity. There will be no voltage drop but supply reversal will pop the fuse every time.
    alfacliff likes this.
  10. #12
    Nov 30, 2010
    16,665
    7,310
    Many manufacturers use polarized connectors so you can not connect the battery backwards.
    GopherT likes this.
  11. R!f@@
    Apr 2, 2009
    8,785
    771
    Or use a schottkey diode in series with the battery
  12. BReeves
    Member
    Nov 24, 2012
    412
    64
    This is what I would do, cheap, easy and as stated no voltage drop.
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    Every mobile HF and VHF transceiver (Ham and Commercial) I have seen has a 30A reverse polarity rectifier across the 12Vdc power input the radio with a 8 to 25A in-line fuse in the +12V line. Some also put a fuse in the -12V line too, but that doesn't involve the reverse rectifier.
    If the installer does the dumb thing of connecting the power backwards, he would instantly smoke the radio if it were not for the reversed rectifier, which typically has a peak surge rating of ≥~500A, so that it can vaporize the fuse...
  14. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    The bridge is very common on 24vdc Hydraulic solenoids where there is a BEMF diode and a LED indicator used, allows connection without regard to polarity mistakes.
    Max.
  15. ErnieM
    Apr 24, 2011
    7,435
    1,625
    As Figi is asking for a zero power loss protection circuit then any and all schemes employing a diode are missing the point. A MOSFET will only loose power due to the drain to source resistance, which can be very very small for modern devices.
    A MOSFET is a most useful way of dealing with things AS LONG AS THE INPUT VOLTAGE IS LIMITED. If the input can exceed the gate to source voltage then either the method is not valid, or some voltage limiting is necessary. A resistor and zener can work well there in many cases, though it may loose some power to run the zener for circuits constantly running over the Vgs limit.
    cmartinez likes this.
  16. blocco a spirale
    Jun 18, 2008
    1,457
    369
    How is a parallel-connected reverse-biased diode not lossless ?
  17. crutschow
    Mar 14, 2008
    13,475
    3,361
    I'm not sure that the cost of a diode, fuse and fuse holder is less then the cost of a MOSFET and a resistor. And if the voltage is accidentally reverse connected with the diode, then you will need to find a replacement fuse (and of course we all have those on hand). :rolleyes:
  18. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Sorry, I was assuming that failure was not an option.
    My bad.
  19. LDC3
    Apr 27, 2013
    920
    160
    You misunderstand how the circuit is put together. The diode is parallel to the load and (usually) reversed bias. When the power is connected correctly, there is no current through the diode. If the power is connected incorrectly, current flows through the diode and blows the fuse.
  20. ErnieM
    Apr 24, 2011
    7,435
    1,625
    On the contrary it is you who miss the implications of your proposal.
    Connect power in reverse, fuse blows, the rest of the circuit is intact.
    Now connect power in proper fashion. Circuit does not operate as there is a bad fuse that needs to be replaced.
    Thus this circuit accepts failure as an option.
