BEST LONG life and advance PIC micro programer.
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Oct 22, 2015.
Thread Status:
Not open for further replies.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
  2. ISB123
    May 21, 2014
    1,240
    531
    Id go with K150.
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    I'd go for the PICkit3. Then you don't have to move the uC between programmer and circuit, and you'll have the debugger function. ...and it works perfect with MPLAB X.
    DerStrom8 likes this.
  4. DickCappels
    Aug 21, 2008
    2,755
    665
    Note that the K150 supports in-circuit serial programming.
  5. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Of the programmers listed only the PICkit 3 is guaranteed by Microchip to support all new devices, along with all existing ones too. It can also be used for in circuit debugging, always a huge help.
    From the descriptions I can't be sure if the others work with MPLAB, PICkit was made to work seemlessly.
    All the others I would lump together as strictly hobby items.
  6. spinnaker
    Oct 29, 2009
    5,065
    1,163
    I agree. Avoid the hassle of any compatibility issues and buy the original. Plus plenty of people have the Microchip programmer so support will be better. Not that the Microchip needs any support as it works flawlessly.
  7. pwdixon
    Member
    Oct 11, 2012
    488
    56
    The only negative is that the PICKit3 standalone programmer app was created by users and has no support at all and is stuck in the past with no extensions for new PICs. Also the standalone app isn't all that good in terms of usability but no-one has taken it up and continued the development, sounds like a good project for someone but I don't have the time I'm afraid.
  8. spinnaker
    Oct 29, 2009
    5,065
    1,163
    What "stand alone app"? I really don't care I use MpLabX which works just fine.
  9. pwdixon
    Member
    Oct 11, 2012
    488
    56
    that's fine as long as you want to use mplab l use milroelektronika and don't want to load the whole of mplab just to use the programmer
  10. spinnaker
    Oct 29, 2009
    5,065
    1,163
    Does milroelektronika's app work with the PicKit3? Does their programmer work in MPLabX?
  11. pwdixon
    Member
    Oct 11, 2012
    488
    56
    No but to re-quote yourself "I really don't care". The original question was what's a good programmer, not what's a good programmer that works with ........
  12. spinnaker
    Oct 29, 2009
    5,065
    1,163
    You are the one that brought up the fact that the PicKit3 won't work or is difficult to work with non Microship software. When the facts are. few manufacturers are going to make it easy for you to use their hardware with someone else's software when they already have the software that does the job. So the fact that there in no supported standalone app for the PicKit3 is irrelevant. Rather the PicKit3 is so widely used, someone wrote an alternate tool, be it, poorly supported.
  13. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Piece of fiction
  14. strantor
    Oct 3, 2010
    4,302
    1,989
    BEST LONG....
    I get emails from that guy all the time. He's a male enhancement drug salesman.
    ErnieM likes this.
  15. pwdixon
    Member
    Oct 11, 2012
    488
    56
    what was incorrect in my post? Because if there really is a better version of the standalone app I'd like to get hold of it
  16. pwdixon
    Member
    Oct 11, 2012
    488
    56
    BUMP
  17. DickCappels
    Aug 21, 2008
    2,755
    665
    This thread has run its course and drifted from the original topic.
Thread Status:
