That's 5amps and a switcher too.it seems circuit specialist is a good choice according it some people
I found this and it seems to be the one I need but it is cheap so I am weary so I ask..have any of you had any experience with this
http://www.ebay.co.uk/itm/DC-Bench-...djustable-0-30V-0-5A-CSI-3005SM-/221376152787
Please Explain???For cheap disposable go with a Mastech
We used then at nat Semi. They worked pretty well.For cheap disposable go with a Mastech
After you repair it the first time and put in larger spec components and better cooling it will probably last 20 years.
Hmm.!I would assume quite a bit of components would need to be replaced to accomplish that.
Basically the entire machine. Heatsinks, chassis, power transformer, power transistors.Not to derail this thread, but what would need to be replaced in a 30V 5A power supply to give it higher current? say maybe 10 or 20A?
Possibly even higher voltage?
by Aaron Carman
by Jake Hertz
by Jake Hertz
