Best capacitors for sallen-key low pass filter
Discussion in 'The Projects Forum' started by przemmo, Jan 6, 2009.
  1. przemmo
    Jan 6, 2009
    8
    I'm going to design such a filter and want to ask You which capacitors are best for that. The Fc is about 2kHz. Polistyrene? Ceramic?
    thx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you need to have a close fit to the calculations, choose a film type capacitor with at least 5% tolerance - 2% is better. The greater the tolerance, the more uncertain the actual onset of the filter.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    It's important that the capacitors have low residual inductance. Ceramics are very good in this regard, film capacitors run a close second. Avoid electrolytics at all cost.
    eric
  5. przemmo
    Jan 6, 2009
    8
