Please read data sheetCan ULN2803 input operate safely above 5 volts?
Why the MOSFET? The 555 can't drive 30 mA?Minke one of these for each segment of LEDs.
The chip is an NE555 or similar timer chip.
The MOSFET transistor is a 2n7000 or similar low current mosfet. (Lower right)
The PNP is any small PNP transistor (e.g. 2n4403, 2n2906, 2N3906)...
This one stays on for about 2.5 seconds. Increase the resistor that is currently 22k. Any value up to 470k should give you a proportionally longer response (220k will give about 25 Seconds).
If you need longer than 47 seconds, you can use a bigger capacitor for linear response as well.
If he wanted to put 3 HBLEDs in series, that would be 3 x 3.3 V = 10 Volts. The 555 is specificed to output Vcc - 2 volts. OP asked for 12V supply and that would be 12 - 2 = 10 volt output. This gives no overhead for current limiting and possibly glitching output.Why the MOSFET? The 555 can't drive 30 mA?
I assumed simple red LEDs, but if it isn't what he wanted anyway I guess it doesn't matter. The 555 was a good idea. Much cheaper and easier. And lights driven from ground, like an automotive system in case he wanted to use a kosher light bulb.If he wanted to put 3 HBLEDs in series, that would be 3 x 3.3 V = 10 Volts. The 555 is specificed to output Vcc - 2 volts. OP asked for 12V supply and that would be 12 - 2 = 10 volt output. This gives no overhead for current limiting and possibly glitching output.
I guess he could use 2 strings of 2 LEDs in parallel for 4 LEDs per segment but it was also an image I had from another post. Last I read of this string, he didn't want the 555 option anyhow.
Yes, good point. I forgot about the grounded connections of automotive. A high-side switching design would have been better.I assumed simple red LEDs, but if it isn't what he wanted anyway I guess it doesn't matter. The 555 was a good idea. Much cheaper and easier. And lights driven from ground, like an automotive system in case he wanted to use a kosher light bulb.
Already did. The answer is above 6v no.Please read data sheet
by Aaron Carman
by Robert Keim
by Jake Hertz
by Aaron Carman
