I remember when I was Grade V, we experiment our urine with this, Benedict's Solution. I remember that once the solution's color became red, brick red, something like that, our urine contains many sugar. Therefore, once the urine became read, person had a U T I, diabetes, something like that.
Now, I don't know if it can be bought from the pharmacy over the counter, without any approval letter. Is this can be bought from the pharmacy over the counter?
I have read also articles about testing your urine by using this solution, Benedict's Solution and found out that after benedict's solution and urine has been combined in a test tube, you have to heat this test tube about 40 to 50 degrees celcius. But, I don't know what should I use to heat the test tube. So, how?
Thanks a lot
Thanks a lot
