Beginners Problem while Learning C++
Discussion in 'Programmer's Corner' started by sailmike, Aug 11, 2015.
  1. sailmike
    Nov 11, 2013
    143
    I'm teaching myself C++ programming from the book "Jumping Into C++". It's a great book so far and makes it easy to learn the language. I'm using Microsoft Visual Studio as the compiler. When I run a simple code the window doesn't stay open long enough for me to read the results. I tried the cin.get(); command, but that didn't work. I've attached the simple code in hopes one of you may recognize a mistake. I was using Code::Blocks through the first 2 chapters, but the program then tried installing malware on my PC, so I deleted that software and went with Microsoft Visual Studio.
    Thank you,
    RRITESH KAKKAR likes this.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Try
    Code (C++):
    1. system("pause");
    or
    Code (C++):
    1.
    2. #include<stdio.h>
    3. // ...
    4. getchar();
    5.
  3. sailmike
    Nov 11, 2013
    143
    You first suggestion worked.
    Thanks!
  4. ErnieM
    Apr 24, 2011
    7,433
    1,623
    Just open a dos box and run your program from there.
    That window stays open until you choose to close it.
  5. Cornel Ionut Vida
    Nov 24, 2015
    In Visual Studio, you can add break points at lines of execution.
    Add one at the last bracket "}" and it will stop there after running the program in debug mode.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    In college i have also studied little bit C++
    remember only Cout<<
