Beginner:Two circuits with the same battery. No way.
Discussion in 'The Projects Forum' started by paldep, Mar 6, 2016.
  1. paldep
    Mar 3, 2016
    41
    I have an audio amplifier that use 3volt to power on and a preamplifier mic that use 1.5 volt. The preamplifier mic inputs in the amplifier through jack 3.5. When i try to use the same battery source the two circuits power on but it seems that there's inverse current flowing.What can i do? I'am a beginner. :( How can i isolate the two power input from each other ? When i use two different batteries all is going very well. When i Connect the circuits in parallel nothing happens! Thanks
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    What do you mean by "inverse current flowing"? A schematic would be useful.
  3. Dodgydave
    Jun 22, 2012
    5,159
    772
    Wtf#, how can you have inverse current with one battery, post a circuit....
  4. paldep
    Mar 3, 2016
    41
    Sorry, i'm bad in english. I can post photos of the pcbs front and retro. Can i?
  5. nerdegutta
    Dec 15, 2009
    2,569
    806
    A close up, in focus, picture of top and bottom.
  6. paldep
    Mar 3, 2016
    41
  7. ScottWang
    Aug 23, 2012
    4,933
    777
    The connection of the Amplifiers and battery should be like this.
    paldep likes this.
  8. paldep
    Mar 3, 2016
    41
    thank you Scottwang -i want to connect the circuits with a single battery of 3,7 volt. how to do this?
  9. Dodgydave
    Jun 22, 2012
    5,159
    772
    You can put a couple of diodes in series with the microphone circuit to drop the voltage down.
  10. paldep
    Mar 3, 2016
    41
    i have in407 diodes. how to wire them? two diodes to ground(-) and positive?
  11. ScottWang
    Aug 23, 2012
    4,933
    777
    If the 3.7V is means that the lithium then when it full charge will be up to 4.2V, and its lower voltage is 3.2V, you could adjust the R1 values to match the current you want.
  12. paldep
    Mar 3, 2016
    41
    i used the circuit posted by Scottwang but the audio from the preamplifier does not pass in the amplifier. If i use separate batteries for each circuits then it work very well. it's very strange
  13. ScottWang
    Aug 23, 2012
    4,933
    777
    Could you check the ID number of transistors for two amplifiers and labeling them in two parts and their position in the circuit.
    Labeling the bjts from left to right as :
    Preamp : Q1 , Q2, ...
    Audio Amp : Q1, Q2, ...
    Maybe you can draw the output circuit of the preamp and the input circuit of the audio amplifier.
  14. paldep
    Mar 3, 2016
    41
    F3K2SVFFHWN77C8.LARGE.gif FK0VHVFFHWN77CB.LARGE.jpg spy ear.jpg i made a reserch and found the schematics of my preamplifier. . the amplifier is based on a ka2209 ic. ,four 103k 100 v, one224k 100sg, two 104 cap, a 0.47uf and a 220uf10v and a led for the on off. sorry but i'm a beginner.
  15. ScottWang
    Aug 23, 2012
    4,933
    777
    If you have the capacitors as 1~10uF/10V~16V then in series with the output - C of Q1(2N2904), put the positive(+) with C of Q1 and the negative to the input of audio amplifier.
  16. paldep
    Mar 3, 2016
    41
    i will try. Thanks!
  17. paldep
    Mar 3, 2016
    41
    Tried. Doesn't work. Thanks anyway.
