beginer
Discussion in 'Electronics Resources' started by qwerty, Jan 12, 2007.
  1. qwerty
    Jan 11, 2007
    im doing engineering and have i have just started studying microprocessor.can any one tell me what else and in what sequence do i need to learn in order to get a sound and wide base of knowledge in electronics.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can I ask what you have already studied as part of your engineering course?
    I will move this to the Electronics Resources forum where this is better suited.
    Dave
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Hi qwerty,
    I would recommend in future that you post up follow up questions in the forums, personal e-mails often get lost in the depths of my inbox!
    From your e-mail you seem to have a good general grounding (BJTs and FETs), but for the purposes of microprocessors may wish to look more towards MSI/LSI/VLSI implementations. You say you have learnt "digital", from this I assume you mean digital design techniques: design tools, view points, HDLs, rudiments of DSD components (combinatorial, sequential, and FSM [both control and data] design), design methodologies through to implementation. Then if so you should look at the next step which is how these elements are integrated into a complete design. The best text I have come across is the Weste and Harris book (website: http://cmosvlsi.com/) which sadly is quite expensive but provide a superb introduction and analysis of microprocessors from the perspective of VLSI circuit deisgn, focusing on the MIPS processor. I suggest you look at getting from your institute library to see if it pitches in at a level you are comfortable with. You can also use All About Circuits - Volume IV as a reference tool.
    Dave
  4. qwerty
    Jan 11, 2007
    hi dave, can you suggest me a project if i do could help me in getting acquainted with the things practically.i hav done quite a number of experiments (digital,analog,communication) but at a very basic level for example making simple circuits with counters,F/Fs etc.maybe if i do something at a higher level i would gain a better understanding.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I would suggest you look at doing the theoretical ground work first - the above book and websites are a good starting point. To help your theoretical understanding, you could also look at the Socratic Project for questions to test yourself - go to the Digital Circuits section.
    Then you could look at using a HDL to implement a design (this is a hardware approach, i.e. you are implementing a hardware design) - say a lock mechanism that only opens when a certain numerical sequence is input. Also look into microcontrollers as an example of a specific function microprocessors (this is a software approach, i.e. you are implementing functionality using software on the existing microcontroller hardware) - there are hundreds of practical projects for implementing a design. This approach will be good since it will introduce you the inner workings of a microcontroller which mirror those of a microprocessor.
    Either of these appraoches will introduce you to many of the components that constitute the building blocks of digital circuits, including microprocessors. From that you will be in a strong position to understand the theory you have looked at previously.
    Hopefully that will give you a little food for thought.
    Dave
