I am designing a beerpong table, will be using some sort of 12v wall wart to power it.
The cups will be backed with neodymium magnets and below them will be a clear acrylic panel with reed switches + LED's underneath. I want the switch to somehow toggle between two different LED arrays under that particular cup. I also want to somehow fade in/out these LED arrays with capacitors but I have no idea how to figure out what caps I need + resistors.
There will be other components in the table including neon cold cathodes (case modders know what I'm talking about), LED chaser circuits, and a hairdryer fan. The rest of these components will be in parallel with the source.
In total there will be about 240 LED's (2 arrays of 5 LED's per cup, 20 cups), 8 12v neon cathodes, 2 fans.
My early schematic so far:
-Does everything look ok so far?
-What capacitors and wiring setup for those caps should I use? I've seen ones with a large capacitor wired in parallel with the LED and smaller ones in series. How do capacitors in these configurations change what resistors I need to use? I'd like to keep this bit relatively simple.
Thanks for the help
Thanks for the help
