Been given an LM3876 to play with.
Discussion in 'The Projects Forum' started by Fenris, Aug 18, 2009.
  1. Fenris
    Thread Starter Active Member
    Oct 21, 2007
    288
    Hi Chaps
    I have been given an LM3876 amplifier chip to play with for a possible voice mod. Reading the data sheet I m not sure if it will run of of a 12VDC supply and single rail at that. If it does work I know it's output will be severely reduced but what can I expect in terms of output?
    regards
    Fenris
  2. Tahmid
    Jul 2, 2008
    344
    27
    Hi Fenris,
    It won't. The datasheet specifies a minimum supply voltage of 18v. So, it wont run off 12v. Anyway, at 18v you wont get anywhere near the 56W the chip can supply.
  3. Fenris
    Oct 21, 2007
    288
    Hi Tahmid
    Ah well. I will just have to build a PSU and use it as a stereo Amp then :D
    regards
    Fenris
