Because Of My Careless?
Discussion in 'General Electronics Chat' started by moorejohn90, Jun 29, 2013.
  1. moorejohn90
    Dec 9, 2011
    57
    Hi, I was carelessly plug the power cord of my KENWOOD(110V) into 220V supply. After a few seconds, I find out :eek: I forgot to plug KENWOOD's cord to 110 transformer. But it was late, my KENWOOD doesn't work anymore. How do I fix it. Which part of KENWOOD are destroyed? Any advice.:confused:
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    Your Kenwood what? Radio?
    Maybe, if you are lucky only a fuse is blown. Did you see smoke or smell anything. Do you see anything melted?
    More information will get better answers.
  3. moorejohn90
    Dec 9, 2011
    57
    No, It is Cassatt that can play CD, tape and MD. No I didn't get any smell. And I haven't open it up? Any advice. Thanks
  4. tshuck
    Oct 18, 2012
    3,531
    675
    If you are hoping to fix it yourself, you will need to open it up...:rolleyes:
    Give a model number and pictures of the insides...
  5. moorejohn90
    Dec 9, 2011
    57
    Model No is RXD-SE5MD(S)
  6. mbohuntr
    Apr 6, 2009
    413
    32
  7. tshuck
    Oct 18, 2012
    3,531
    675
    If your power supply is like the one shown here, I would look at your caps, diodes, and, possibly, the regulators... and verify the power amp output...
    EDIT: Looks like mbohuntr beat me to it! :)
  8. moorejohn90
    Dec 9, 2011
    57
    Checking, for a minute
  9. moorejohn90
    Dec 9, 2011
    57
    It look like the same. And What I found out is the fuse is turning black. Is it the symbol of blow out? Any advice?
  10. #12
    Nov 30, 2010
    16,671
    7,319
    A fuse that changed color is usually bad, and you're really lucky if that's all that went wrong!
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    Very unlikely the fuse is the only thing gone. Blowing the fuse meant high current flowed through it and that current had to go somewhere.
    The diagram doesn't even show in input line fuse.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It will have blown the primary of the mains transformer, which then took out the fuse. So a new power transformer will be needed.
    There may be something blown after the secondary of the power transformer, but not always.
  13. Relayer
    Jan 1, 2013
    18
    You're going to need the aid of a digital multimeter. If you don't have one, then get one. Without it you're searching in the dark.
    Regards,
    Relayer :D:D:D
  14. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Even with a multimeter, without knowing what the part was or a schematic or service manual plus some electronics skills the OP is probably better off going to a repair shop.
  15. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    That's happened to me as well (electrician picked up the wrong bus..) New power xfmr fixed it. (Bogen PA system).
