I've built the below circuit, to power up my Receiver in RC airplane from 2S LI-Ion battery. This circuit cuts votage from ~8v to ~5.7V.
At first, worked ok. However, I started to "load" the servos, by adding weight onto control surfaces. I measured max current draw from the battery, it is about 1.5A at 80% load ( was not able to load more, as I was scared to break the wing/tail control surfaces).
My two LM7806s are without heatsink for now. And they get hot. Other thing, the voltage drops to 4.3V. I.E, it does not keep straight 5.6v....
The input voltage is constant, fluctuates between 7.6-8.2V.
I increased the value of output caps to 100mf/25v, and put one big 2200mf/25 cap at the input of ICs.
the LM7806 is rated for 1.5A (which I doubt now). The Schottky diodes which I use, FR155, is rated for 3A. But they also get hot...
I'm planning to add 2 more similar branches, so will have total of 4 7806s in paraler, as shown in circuit.
Any ideas why I'm not getting regulation even at 50% of components rating?
Any other BEC circuits that you can suggest me looking at?
These voltage regulators generally need at least two volts more input than the regulated output. Google "dropout voltage".
Also, voltage regulators are not perfectly matched for output voltage so connecting them as you propose may cause one leg to handle more current than the other. So much that you get thermal runaway as one gets hot then starts to carry more and more load. I would add a small value resistor between the diode and regulator. Resistor value only has to be big enough to accommodate expected difference in voltage between the two devices at your max current draw.
For example, if the DATASHEET says 6v +/-2% (0.24v max) and you expect each regulator to put out 0.75amps, then select buffer resistors of 0.24/0.75=0.33 ohms.
Also, if you are controlling motors which can cause inductive kickback current, you should add a diode between your ground and the output of your schottkey diodes (reversed biased). That way no current will flow through the diode in normal operation but the diode will allow current to flow in the reverse direction as the motors slow to a stop.
Thanks. Checked on datasheet, it has 2v dropout voltage. I thought 8.2v is enough to be regulated down to 5.6v? In the other hand, if I add one more cell, it will be ~12v to be regulated. And I will have more power dissipation as heat.
Regarding the resistor, I will add them. Looks like 0.25W should be enough. Also, 7806 is rated at 1A max. So I will plan with 50% safety factor. As you mentioned, it is +/- 0.2V. I will then plan for 0.24/0.5=0.48 Oms. Will see what close value I get. Based on this, resistor power should be 0.12W ? right? 0.25W resistor must work OK.
one clarification I need is regarding your last point, diodes...is this what you mean should be done? picture attached
for bias diodes, 1A rated 1n4007 is available for me. Is this sufficient? Or should I look for more?
Regarding the other type of BECs....I can plan and build SMPS, based on CD4047. Can step down from 8v to 5.5v exact, with feedback. With 2 power mosfets and small torroid core should be sufficient. But the size obviously increase..
OK, I've built 3 parallel circuits. LEDs in fisrt 2 branches light up, the voltage across them is around 2.4V. The LED on 3rd branch does not light up the voltage across it is 1.3V. The resistor value is the same for all 3 branches. I have put actually 270ohm resistors. I may plan to reduce the resistor values, maybe down to 200ohm.
The IC's get hot without the heatsink. So one must be added.
I'm planning to build 6 parallel branches. Is there any downside? The original author mentions that number of branches can be increased infinite, to achieve amount of regulation. Well, 6-7 branches should work ok for me.
In the other hand, I'm also thinking to make simple LM317 regulator, with bypass transistor. Did come across one 12v high current power supply somewhere. Just need to find it....
Also came across the regulator on LM317. With a pair of darlington transistors. Seems like handling about 8-10 amps. It is also shown on ICs datasheet.
Any feedback on this? and also on few posts above?
BEC= battery eliminating circuit, this is for RC aircraft. The receivers/control servos can handle 6v max. So if you put bigger battery, you need to cut it down to 6v.
I came across the 6 in parallel version on the web, and it looked simpler for me. But as you mentioned, and I found in lm317, I can use one IC to control high current with transistor
Also, for wattage, I assumed for each regulator to handle 0.5Amps. there fore.
I doubt you can buy an LM195 nowadays. You're going to wind up with some other power transistors. Quantity depends on how fast you can move the heat out of them.
So...what's the bottom line on the amount of amps you need?
yes, as I mentioned in my earlier post, I will probably will use the replacement for power transistor in my local area.
All servos together pull about 2amps. But this is in static condition, I do not know how much more they get loaded during the flight, when I do 3D maneuvers.
Ive got 3x Futaba S3010 servos, and the manual says they can pull as much as 2A at heavy loading. and also have 3x Futaba S3004 standard servos. They pull maks 1A.
SO...theoretically, worst case I need 9A. with some safety factor
That's correct. However, the point for adding extra cell was not to increase the capacity/amperage, but increase input voltage so delta V is more than dropout voltage.
Maybe you ment something different, please explain.
