Beautiful Homemade
Discussion in 'General Electronics Chat' started by Dr.killjoy, Dec 23, 2013.
  1. Dr.killjoy
    Apr 28, 2013
    1,210
    158
  2. Metalmann
    Dec 8, 2012
    700
    223
    Downright sexy!:cool:
    Must have really been a labor of love:
    "After pouring the resin and allowing it to cure, he squared up the block on a belt sander, chamfered the edges with a router, and finally polished everything up with wet/dry sandpaper and Brasso."
  3. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Devil of a job to service, however. :eek:
    Max.
  4. atferrari
    Jan 6, 2004
    2,669
    784
    What I cannot understand (believe) is that you can get a crystal clear surface by polishing which is no more nor less than actual microscopic scratching all over...!
    Impressive!
  5. Metalmann
    Dec 8, 2012
    700
    223
    Yeah, just how lenses are ground.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  7. Markd77
    Sep 7, 2009
    2,803
    594
    I've done it, it takes ages, you have to use a lot of grades of wet and dry paper up to 1200 grade or higher, then brasso on a cloth wheel does give a good finish at the end. I bet he had to use a shaker and maybe vacuum to get rid of bubbles as well.
  8. Metalmann
    Dec 8, 2012
    700
    223
    I've polished a few acrylic pieces using a propane torch.
    As long as you don't OVERheat it.;)
  9. ErnieM
    Apr 24, 2011
    7,440
    1,627
    Very good. +1.
    I just wish his encapsulation method was a little less "hands on."
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    First thing I thought of: going to be tough changing those electrolytic caps when they fail after about 5000 hours of service.
  11. trader007
    Feb 27, 2010
    222
    19
    no kidding!
  12. tubeguy
    Nov 3, 2012
    1,157
    197
    Yep.
    But then it can begin it's second life as a beautiful coffee table conversation piece. :)
  13. kubeek
    Sep 20, 2005
    4,689
    806
    Or the output jack for that matter, which will likely come much sooner.
  14. Sensacell
    Jun 19, 2012
    1,184
    277
    When it "Bricks" - it's already "Bricked"
    Beautiful piece!
  15. GopherT
    Nov 23, 2012
    6,321
    4,046
    Unfortunately, it is a lot of work for a headphone amp driven be an op amp that is intended to drive a minimum 600 ohm. I just can't figure out what audio source would benefit from such an amp. The "CMoy headphone amp" schematic is in the link below. The virtual ground is laughable - why dont they just take the node between the two 9-volt batteries instead of between two 4.7k resistors.
    A lot of acrylic polishing for a novelty that never should have been taken off of the breadboard.
    Original website describing the "CMoy" (who decided that an inverting amplifier circuit needed a name - other than, "inverting amplifier"?).
    http://tangentsoft.net/audio/cmoy-tutorial/
    Schematic
    http://tangentsoft.net/audio/cmoy-tutorial/misc/cmoy-tangent-sch.pdf
