Beat frequency of turning folk
Discussion in 'Physics' started by mndewa, Feb 11, 2013.
  1. mndewa
    Sep 16, 2012
    7
    a turning folk when sounded with a folk of frequency 256Hz gave 4 beats/second. when small beat of wax was attached to a prong of the folk of unknown frequency 3 beats/seconds were produced.what is the frequency of unknown
  2. MrChips
    Oct 2, 2009
    12,650
    3,460
    The answer should be obvious.
  3. logearav
    Member
    Aug 19, 2011
    248
    Hi mndewa,
    The frequency should be either 256+4 or 256-4 which means either 260 or 252. On loading with wax, the frequency will decrease. So the frequency of unknown fork is 252. Hope this helps.
  4. Kermit2
    Feb 5, 2010
    3,854
    968
    If the freq. of unknown decreases with a wax load, then the answer would be 260 Hz.
    when loaded the freq of unknown became closer to the standard as in 3 beats vs 4 beats unloaded. Therefore the unknown would be higher.
    logearav likes this.
  5. logearav
    Member
    Aug 19, 2011
    248
    Yes Kermit2 is correct.
