IIRC lead-tin shells rely heavily on significant copper inclusions for load bearing capacity.A little googling comes up with lead-indium being a harder alloy than lead-tin. Used for a (better) surface on the rod bearings in a car engine.
In Australia we call them "white metal" bearings.
Drill rod/O1 is called "silver steel", I'm pretty sure, in the UK.Don't you also call Drill Rod, O1, and Tool Steels, white metal?
Thought I read that years ago?
Around here there are casting places that do "white metal casting" almost always a zinc or "pot metal" process. Aluminum casting is mostly not called "white metal" in the trade.White metal usually another name for a soft aluminum like alloy, probably with Zinc, and is totally different from the first three.
Max.
Tool steel is sometimes referred to as silver steel, but it may be colloquial.Don't you also call Drill Rod, O1, and Tool Steels, white metal?
Isn't drill rod HSS (high speed steel)?Drill rod/O1 is called "silver steel", I'm pretty sure, in the UK.
Thread starter | Similar threads | Forum | Replies | Date |
R | A few questions around Source and Target language (wrt compilers) | Programming & Languages | 3 | |
E | Half Bridge soft switching questions | Power Electronics | 3 | |
Fixed mate for a pillow block flange bearing? | Off-Topic | 40 | ||
Bonding light metal to a bearing? | Off-Topic | 16 | ||
Micropump Bearing Lubrication | General Electronics Chat | 16 |
by Jake Hertz
by Aaron Carman
by Duane Benson
by Aaron Carman
