Beams
Discussion in 'Homework Help' started by Agata78, Feb 28, 2013.
  1. Agata78
    Feb 28, 2013
    I need a help with this questions. I have a few books from library but they are not really good.
    Choose a beam and a column. Research and explain how you would select standard rolled steel sections for the beam and the column according to specifications.
  2. panic mode
    Oct 10, 2011
    1,328
    305
    where do you connect wires to beam and column?
    how is this electronics homework question?
  3. tshuck
    Oct 18, 2012
    3,531
    675
    There may be some people here with a ME background, though the likelihood is pretty small...
    OP, you may be better off going to a ME forum or a physics forum...
  4. shortbus
    Sep 30, 2009
    4,094
    1,678
  5. mcgyvr
    Oct 15, 2009
    4,789
    974
    Research and explain why you would register for an electronics message board and post an architectural/structual question.
    Is it smart to go on a quilting message board and ask them how to change a flat tire?
    BruceBly and shortbus like this.
