BCD to Decimal decoder
Discussion in 'General Electronics Chat' started by jpanhalt, Oct 13, 2008.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    BCD to decimal decoders are common, but the ones I have looked at all have logic high/low states. Is there such a decoder that instead has a high-impedance (i.e., open) state and low state?
    John
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The high-impedance state is intended to isolate the logic element from the system. What would be the point?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Open collector?
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Bill,
    Open collector will work, I think. Is there a family that is open collector?
    Beenthere,
    At an abstract level, one can have: yes, no, and don't know/doesn't matter.
    At a concrete level, I am playing with a set of resistors to make a digitally selectable output for a voltage regulator. The schematic has been shown on this forum. This is from the ST L200 datasheet:
    That works easily with, say, 4 discrete values. I want to select voltages between 22 V and 12 V in 0.1 V steps. An ovbious way to do that is with BCD thumbwheel switch and BCD to decimal decoder on the board. By using either transistors or blocking diodes, I think I can get it done, but an open collector type of logic chip would make it easier.
    John
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    After morning coffee, I was inspired to do more searching. It appears the SN74145, 54145, and 74LS145 are open collector.
    Any others?
    John
