First of all, I'm asked to design a 4-bit calculator that accepts tow inputs which are in BCD and I have to convert them to Binary, so when i use the truth table the inputs and outputs will be identical because it is a 4-bit calculator.
should I get the logic diagram for BCD-to-Binary?,because the BCD and Binary numbers are the same in the digits for example 0001 in Binary is the as 0001 in BCD which is 1
Also,in logic work I used the ic 7447 to show the number in 7-segment as u can see here ( of course u should have logic work installed to open the following file)
http://www.zshare.net/download/827023905c043b91/
but it doesn't work I dont know why
sorry for that but I'm really really really confused
thank you
thank you
