Bcd to bin routine
Dodgydave
Joined Jun 22, 2012
11,302
I want to add the total in an A/D conversion in adresh and adresl files and then split them into hundreds tens units, i know how to do the a/d routine, just need help with adding the two files using the conversion, maximum would be 500, anybody got any ideas how to do it in ASM using a pic16f690.
Papabravo
Joined Feb 24, 2006
21,225
Sure. You can do division by repeated subtraction. You start by subtracting 100 from the A/D result until the result goes negative. Each time the result is positive you increment a counter. When the result goes negative you add 100 back and that is the reminder.
Now you switch to 10. Repeatedly subtract 10 until the dividend goes negative. Increment the 10's counter each time the result is positive. When the result goes negative add the 10 back in and the result will be the remainder.
Dodgydave
Joined Jun 22, 2012
11,302
I ready have that working, for adresl, i need to add the contents of addresh to the Huns tens units, its the adding of two 8bit files hows that done???
Papabravo
Joined Feb 24, 2006
21,225
It's pretty easy
  1. Add the low bytes together
  2. Add the high bytes together WITH CARRY
All 8 bit processors have a carry flag that is used in multi-byte arithmetic. When the carry is 0, then the add with carry instruction is just like a normal add. When it is a 1, then the add with carry adds two bytes plus the carry bit in a single operation. You can extend this concept to operands with any number of bytes.
Dodgydave
Joined Jun 22, 2012
11,302
I have it working now , done a bin/bcd routine from microchip web site. thanks
Rich (BB code):
LEFT JUSTIFIED, UPPER 8 BITS IN ADRESH, LOWER 2 BITS IN ADRESL
Unpack
        swapfw   bcdH                 ; unpack BCD digits
        andlw   0x0F
        movwf   thou
        movfw    bcdH
        andlw   0x0F
        movwf   huns
        swapfw   bcd
        andlw   0x0F
        movwf   tens
        movfw    bcdL
        andlw   0x0F
        movwf   units
        return
; Upper 10-bit Binary To Packed BCD Digits
Convert_bcd
        clrf    bcdL            ; clear result
        clrf    bcdH
        movlw   .10             ; set bit counter
        movwf   count
bcd_lp  movlw   0x33            ; adjust BCD result
        addwf   bcdL ,f
        btfsc   bcdL,3
        andlw   0xF0 ,f
        btfsc   bcdL,7
        andlw   0x0F,f
        subwf   bcdL ,f
        movlw   0x03
        addwf   bcdH
        btfss   bcdH,3
        subwf   bcdH,,f
        rlf     ADRESL ,f           ; shift out a binary bit
        rlf     ADRESH,f
        rlf     bcdL ,f           ; into BCD result
        rlf     bcdH ,f
        decfsz  count ,f          ; repeat for all bits
        goto    bcd_lp
        return                  ; exit
