BCD input to 3-7 segment display help
Discussion in 'The Projects Forum' started by remy1987, Mar 1, 2013.
  1. remy1987
    Mar 1, 2013
    I have I.D. boxes at work that identify stamping dies with a number from 1 to 255. I want to make a tester that can plug into the box and give me a readout of the 3 digit code for that box. Right now each box is normally read by the PLC. The pin out is as follows. Pin A=24 vdc, B=1, C-2, D=4, E=8, F=16, G=32, H=64,and I=128. Pin A is always jumped to the proper pins for the corresponding die number. I need the tester to add the values of each pin and display them on the 3 digit display. The plug will not have power on it so it does not have to be 24 vdc. I have some experience with electronics but not enough knowledge about specific hardware needed for this project. Any suggestions would be very helpful.
  2. MrChips
    Oct 2, 2009
    12,638
    3,456
    This is not easy to do with regular logic ICs.
    This calls for a microcontroller (mcu). How comfortable are you with mcu chips?
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Use a large EPROM if you have one available.
    3 digits (8 bit each) - 12 bit
    12 bit - 2 EPROMS in parallel
    1000 entries.
    You need 2x2716 EPROMs.
  4. crutschow
    Mar 14, 2008
    13,505
    3,376
    Here's a discussion of binary to BCD (decimal) conversion that may be of help.
