BCD for LEDs
dyeraaron
Joined Oct 27, 2008
57
I have 8 LEDs coming off of a 7490 Decade counter......now one decade counter only has 4 outputs for ABCD......Does a second 7490 pick up the EFGH or is that just another ABCD, Obviously, you can't jumper each one because they have specific pins such as the 4 inputs and 4 outs, the Vcc and GND, along with the 2 clocks....so my question is this....I have a Frequency input going into the decade counters....do I jumper each pin with the input so I can get my BCD @ my LEDs?
SgtWookie
Joined Jul 17, 2007
22,230
A single 7490 has ABCD outputs that represent a decimal digit from 0 to 9. If you have two of them that you want to cascade, you'll need more gates. It would be easier to use something like a couple of 74160's. The 2nd counter would have bits ABCD of the 2nd decimal digit (0 to 9).
As far as the LEDs - TTL is very poor at sourcing current; less than a milliamp. The outputs might sink up to 16mA, but that would mean that your LEDs would be ON when the output was low. You'd really need to use NPN driver transistors to invert the logic signal.
dyeraaron
Joined Oct 27, 2008
57
So I use (1) 7490 and my ABCD output goes to a 7447 but before those inputs, I paralleled the 4 into a resistor pack and into LEDs grounded by an NPN with a VCC into the base along with a resistor at the base. In the beginning though, I was thinking I'd need 8 inputs to the resistor pack to my 8 LEDs.....not so clear about that yet.....but back to the 7447s....looking at those datasheets and some text in my books....theres pins labeled RBI/RO or something like that...I know it stands for Ripple banking or something along that nature.....is this the output from one to the other 7447 so these 2 decoders can drive 2 seperate 7 segment displays?
