Battle of the hall effect sensors part 2!
Discussion in 'General Electronics Chat' started by kalikid1210, Dec 16, 2008.
  1. kalikid1210
    Jul 15, 2008
    21
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I tried searching for Hall-effect sensors with '502' in their part numbers a day or two ago with somewhat inconclusive results. Seems that the sensors I found indicated they were the "latching" type.
    I don't know why yours would be a latching-type Hall-sensor unless there was a coil that received pulses to slowly build up a magnetic field to turn your latch off. That might be a way to establish PWM on the basis of how near or how far the Hall-effect sensor was from the coil being energized.
    But I don't know enough about your throttle control. Trying to modify something like that definitely has the potential for injury, as it's a control for a motor-driven vehicle.
  4. kalikid1210
    Jul 15, 2008
    21
    SgtWookie,
    One of the links was to the EXACT sensor with the #502, as in EW-502.
    And this application will not be for a motor drive VEHICLE...no 'Red Asphalt' here!
