if both the terminal of the battery are shorted (by an ideal conductor)then ,both the terminal of the battery will be at same potential .if this is the case then the current should not flowthruogh the conductor.is this possible
you might want to learn about superconductivity in that case.if both the terminal of the battery are shorted (by an ideal conductor)then ,both the terminal of the battery will be at same potential .if this is the case then the current should not flowthruogh the conductor.is this possible
by Duane Benson
by Jake Hertz
by Jake Hertz
