If AA battery is connected to small resistor, 0.5 ohm, for about 2 minutes and disconnect the resistor to measure the voltage across the battery,will the voltage across the battery recover right after disconnecting from the resistor?
I'm trying to measure the open-circuit voltage, which is the voltage across the battery, but seems like I'm getting different value depends on how long I wait from the disconnection.
Is there better way to find the open-circuit voltage?
Sorry if this doesn't make much sense... Kind of hard to explain...
well any helps will be appreciated
