I found this in a previous post
My question is this
I rigged up enough alkaline D in seires to make 9 volt dc approx.
The camera I have plugs into the house with an adapter cord that says
input 120vac 60hz
output 9volts dc max current drawn 500mA
And in the manual I read that the camera runs on 9volt dc with 100mA to max 150mA.
Also in the manual you can send away for a battery so you can use the camera without haveing it plugged into the house with the 6 ft adapter
My question is why won't my D cell batteries work to power the camera?
Going by the chart seems it should?
Here is the links to the camera and battery pack for it.
http://www.smarthome.com/manuals/5946.pdf
http://www.jascoproducts.com/products/pc/viewPrd.asp?idproduct=836&idcategory=0#details
Curious why the D cells won't work 19500mAh but maybe when you but them in series it is not good enough to make the equivalant of Lithium 800mah.
The only difference is this battery is rechargeable mine is not..... but it still should work.
Or maybe the mAh are based on different current per hour that screws up the powering of the device .....etc
Thanks for anybody that clears this up...
If I by the battery pack will it last long for recharging purposes....
Rich (BB code):
Battery capacity in mA*hr
Alkaline C-Zn NiCd NiMH Lithium
AA 2700 1100 600-1000 1700-2900 3000
AAA 1200 540 800-1000
AAAA 625
C 8000 3800 4500-6000
D 19500 8000 900-11500
9 volt 565 400 120 175 1200
CR123 1500
CR2025 dia=0.787, height=0.098 160
CR2032 dia=0.787, height=0.126 225
CR2450 dia=0.965, height=0.197 610
Silver Oxide Volts mA*hr Alkaline Volts mA*hr Dia, in Height, in
SR41 1.55 42 LR41 1.5 32 0.311 0.142
SR44 1.55 200 LR44 1.5 150 0.457 0.213
input 120vac 60hz
