Enclosed is my battery wiring drawing.
If I turn CB 1 to on, I will get 12V, then turn off.
If I turn CB 2 to on, I will get 24 V, then turn off
If I turn CB 3 to on, get 36V, then off
If I turn CB 4 to on, get 48V, then off.
There are 4 batteries that connect in series and each wire is connect to each CB and all together coming to one terminal + and this will feed into the unit.
One thing that I am worry is if both CB 1 and CB 2 turn on at the same time, or CB 2 and CB 3 turn on at the same time..., so the battery will explore.
Does anyone have any idea how to re-draw it or add some parts in order to make sure the battery bank is safety if someone accidently turn on both CBs to on at the same time.
Thanks,
Ken
Thanks,
Ken
