Battery Usage
Discussion in 'General Electronics Chat' started by bhuvanesh, Aug 30, 2014.
  1. bhuvanesh
    Aug 10, 2013
    268
    i have found a computer UPS battery which is giving 9 volt but only 0.5 amps.is that can be used for anyother purpose?
  2. wmodavis
    Oct 23, 2010
    737
    150
    Sure as long as that purpose can use 9V @ .5A . Many devices use a 9V battery. Whether your UPS battery will supply enough energy depends on its residual capacity vs the needs of a projected usage. Your question is pretty nebulous and therefore needs more specific information to enable providing real useful answers. The battery you mention likely has 2 shorted cells so depending on the condition of the remaining ones you might get some use from it.
    bhuvanesh likes this.
  3. samuel.whiskers
    Member
    Mar 17, 2014
    95
    Presumably this is a 12V SLA?? If it has been charged with a working charger, and only manages 9V, I'd pronounce it dead..... How long can it deliver 0.5A for at that voltage??
