Battery trickle charger??
Discussion in 'The Projects Forum' started by badspell68, May 12, 2008.
  1. badspell68
    May 10, 2008
    20
    My car sits for long periods of time without being used, so I would like to get a solar trickle charger. Any advice on what unit would be best for keeping a good charge on a car batt?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Are you thinking of a home brewed device, or a commercial unit?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    I bought a solar trickle charger for only $9.99 on sale. Its output is 2.25W at 12V-13V and has a cigarette lighter plug.
  4. badspell68
    May 10, 2008
    20
    Thinking of an off the shelf one...Have a fav?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. badspell68
    May 10, 2008
    20
    The first one...would it really keep a car bat up to par?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I'm dubious about it being able to keep it up.
    It would depend upon how much current is being used by your vehicle when it's not in use. There is always SOME drain, even just to maintain the radio memory and the clock.
    And a solar cell only generates power during daylight hours, perhaps 1/2 day. Obviously, more in summer, less in winter.
    So, if it's putting out 110mA in the light, it's putting out 0mA in the dark - or averaging around 55mA through the day.
    You would need to measure your vehicle's static current drain.
    First, charge your battery completely, perhaps for a day on a trickle charger. Then let it sit for several hours for the "surface charge" to drain off.
    Then, disconnect the negative cable, and connect in an ammeter. See what the drain is.
