Hope there is someone with good electrical knowledge on here i need a wiring diagram for a battery tester/timer.
Spec's:
* For testing 6v - 8ah and 5ah batterys
* It needs to use no more than a 24v supply
* i want it to do a count to 10 lighting up 10 leds (using a 555timer and a decade counter) - as this is happening i need the
0 - 7 voltmeter to check the battery that will be hooked up and when all the leds are lit (after 10 seconds) for it to all reset/finish testing
So basically as i am at a total loss on how to do all this, very limited electrical knowledge! i would greatly appreciate any suggestions!
i hope someone will have the time to draw me a wiring diagram of how i can do this! as i am totally at a loss when it comes to compiling all this or knowing what resistors and types of chip etc. that i need. I also need it to be either CMOS or TTL, and the chips need to be only one or the other.
i have access to all the components i need resistors, leds, etc.
I hope someone will point me in the direction of help!
please contact me via E-mail if you can help!
If you are good at this sort of thing but un-wiling to spend some of your time on this as it may take a while to do, or possibly 5mins if you are really good?
I would consider some type of compensation for your time taken for a good wiring diagram $
Thank you
Spec's:
Thank you
