New to this Forum, Stumbled upon a couple of t threads about building a Battery tab welder from a Junked Microwave, or Capacitor / SCR etc. Those are all good but I already have a Rivet Stud Welder that works Great for what it was intended to do...I want to know if anyone have ever used one to make a Makeshift spot welder or Battery Tab Welder. I dont want to spend a whole lotta time building a Tab welder when I can use what I have if it will work. Has anyone here ever made a Battery Tab welder from a Rivet Spot welder? In theory I'm thinking it should work. All I need to do Weld some Tabs to a Battery pack that I am rebuilding. Fittment is Tight as I have already Bundled the NiCads but need a Thin strip welded to them so that I can charge the Group inside the original Scanner Battery pack enclosure...Then I'll probably never weld another battery in my life....This is why I don't really want the hassle of hunting down parts, and building something I'll only use once or so.
thanks
thanks
