battery swapper
Discussion in 'The Projects Forum' started by PETER JAMES-2, Jul 18, 2012.
  1. PETER JAMES-2
    Jan 1, 2012
    Hi everyone
    Help==not electronics schooled but I build projects--big learning curve!!!
    To begin with--thanks in andvance for assistance.
    I have several questions
    First question:
    I have two batteries--one hooked up to a circuit-(bat 1) and a
    spare-(bat 2).
    When bat 1 drops below a certain voltage ( I would like to be able to set this voltage)--I would like to automatically disconnect bat 1 from the circuit and have bat 2 replace it to continue driving the circuit.
    Would I use a zener and a relay or ????--no idea were to start.
    More questions to follow
    Thanks P_E_T_E_R
  2. BMorse
    Sep 26, 2009
    2,675
    234
    you can get voltage detectors with preset triggering levels to switch between the batteries...... and you can also use one to switch back to battery #1 once battery #2 gets to a certain level.... that's if you already replaced battery #1 or the circuit would end up oscillating between the 2 batteries..... or include a comparator circuit to monitor the voltage level to switch between batteries....
    What size batteries and what voltage????
  3. wayneh
    Sep 9, 2010
    12,382
    3,237
    Boaters do this routinely but usually want to manually choose which battery is being drawn down. I believe it's common to use a "starting" battery for starting the motors and a deep cycle battery for lights and radio when the engine is not running.
    Anyway, why do you want to switch instead of just using two batteries in parallel? They'll both last longer.
  4. PETER JAMES-2
    Jan 1, 2012
    Hi BMorse and wayneh:
    Thanks for your comments. I try to supply relavent info so you can better understand whats up.
    I would like to build my own circuits--I don't want to buy some kit unless of coarse it makes more sense to do so.
    What I want to do is build a motor--(similar to a John Bedini SSG)
    but with some of my own ideas.
    I have an idea of the way I want to go and in order to not get over whelmed, I thought I would work on one circuit at a time so that I could understand what's going on--(not being an electronics dude).
    FIRST STEP:
    --build a circuit to monitor the voltage level of each independant storage battery--(12 volt)--(sealed lead acid---7.2, 12 and 32 ah are the sizes I will be using--not together).
    --if battery drops below a level--(selectable in range--say 12.2v as an example) --to disconnect it from the circuit.
    --to be able to direct this battery to be recharged or--have the ability to redirect the voltage to be used as required
    BASICLY HAVING THE ABILITY TO MONITOR AND CONTROL INPUT AND OUTPUT OF BATTERIES INDEPENDANTLY
    SECOND STEP:
    --build a circuit to monitor and control the voltage level of independant Storage Capacitors
    --also on a 12 to 24 volt system.
    --as the capacitor charges I want to be able to direct the output to power a coil or direct it to a storage battery.
    Basically what I want to build is a capactive discharge motor and to be able to control and set all voltage levels.
    I hope this is a little clearer of what I am attempting to do.
    I have already built the motor---these are some things I'd like to do to have better control.
    Once again I appreciate any assistance
    Thanks P_E_T_E_R
  5. wayneh
    Sep 9, 2010
    12,382
    3,237
    Uh oh, you're not pursuing "free energy" are you? Impossible.
