Battery selector and Comparator
Discussion in 'The Projects Forum' started by asvinimurugaiyan, May 21, 2013.
  1. asvinimurugaiyan
    May 21, 2013
    6
    Hi friends,
    Here i have attached a circuit file.In that circuit VOUT is dropped, when the comparator is connected to the circuit. What is reason for that voltage drop?. Is there any solution for that?. please refer my attachment file.
  2. asvinimurugaiyan
    May 21, 2013
    6
    Hi friends,
    Here i have attached a circuit file.In that circuit VOUT is dropped, when the boost regulator is connected to the circuit.we are using NCP1402 boost regulator. What is reason for that voltage drop?. Is there any solution for that?. please refer my attachment file.
  3. wayneh
    Sep 9, 2010
    12,394
    3,246
    You've shown the comparator as a 2-pin device. I don't know what that means. Are you referring to just the power pins?
    RamaD likes this.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    The drawing is pretty incoherent. This is not meant as an insult, but do you know what a comparator is? Or what is the boost regulator, have a data sheet?
  5. asvinimurugaiyan
    May 21, 2013
    6
    comparator is 14pin LM319N ic. i m just put the block in the circuit.
  6. asvinimurugaiyan
    May 21, 2013
    6
    boost regulator is NCP1402. i m having a datasheet.drawing is not important. "what logic in that?" that's matter........... ok.......
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Uh, no. Accurate schematics are vital. It's like asking how tall is that without giving a clue what item/person you are talking about. Very few people here can read minds.
    RamaD likes this.
  8. asvinimurugaiyan
    May 21, 2013
    6
    without clue ah???? what clue you want? i told , we are using NCP1402 boost regulator na.
  9. RamaD
    Dec 4, 2009
    254
    33
    What do you want the circuit to do?
    The MOSFET symbol is not clear at all. The gate is opposite to the source terminal and the
    arrow is connected to the source terminal from the middle. It is not the case with your diagram. Which is the source and drain in your diagram?
  10. asvinimurugaiyan
    May 21, 2013
    6
    In MOSFET, 1.2V power connected to source, and the output taken at the drain. we are using IRLML6402 MOSFET.
  11. RamaD
    Dec 4, 2009
    254
    33
    Gate is not made sufficiently negative to turn on the MOSFET. Voltage dropping is because the MOSFET is in linear region - barely into conduction, if at all!
  12. Ramussons
    May 3, 2013
    562
    92
    What does the comparator(s) compare?
    Ramesh
