That's fantastic; like I said, I'm a total beginner, so I think I'm just about following it - if the resistor is less than 150 ohms I guess that means that the LED is getting too much current and burns out? And the resistor has to be 60mW because that's how much power is in the circuit? Does that mean that the LED also has a power rating of 60mW? Sorry if my questions are too basic, I'm trying to learn this stuff myself and finding the right steps on the internet takes a LOT of searching I got the old Forest Mims "Getting Started.." book and I've ordered his kit from Radio Shack. I think getting a handle on basic electronics is considerably harder than basic computer programming!Here's an example. A typical LED load is about 20 mA. For a 3 volt battery, you'd need a load resistance of (3 volts)/(0.02 A) = 150 ohms. The power rating of the resistor needs to be more than the current through the resistor times the voltage across it. Here, that's minimal at 3(0.02) = 60 mW. If the battery was unable to keep a voltage of around 3 volts across a 150 ohm resistor, it's time to put a tag on its toe and send it to the morgue.
Thread starter | Similar threads | Forum | Replies | Date |
LM393 based battery maintainer question | Power Electronics | 3 | ||
C | charging a 9 volt battery question | Power Electronics | 13 | |
S | Battery & Power question | Power Electronics | 12 | |
Victron Battery Protect teardown and question about the isolation. | General Electronics Chat | 3 | ||
J | Lipo battery question | Technical Repair | 2 |
by Duane Benson
by Jake Hertz
by Aaron Carman
by Jake Hertz
