In basic circuit analysis, you assume that things that are not connected have infinite resistance between each other. If they are not connected, no current flows. V = 0 * inf = indeterminate. Ohms law gives you no information here. As long as you have infinite resistance between two points, you can have whatever voltage between them you want and no current will flow. Take a battery for example: V = 1.5V, leads are not connected so R = inf. I = V/R = 1.5/inf = 0. You do not need current to have a voltage.hobbyist said:I'm sticking strictly with ohms law, that in effect says a voltage can only exist when a current is flowing through a resistance. V=I*R
studiot, my entire point here is based on capacitance. You have to include capacitance to understand what I am talking about. All your arguments are neglecting capacitance - in other words, you are saying that the voltage of an object can change instantly. If you keep this assumption and try to analyze the two plates of a capacitor, you will be forced to say that they are a nothing more than an open circuit: in other words, when you connect the plates of a cap to a supply, you have to say that their potential difference is instantly the potential difference of the supply. As I'm sure you know, this is not the case - it takes a finite amount of time for the potential difference between the plates of a cap to reach that of the supply. And all the while, current flows. Once the potential differences are equal, current stops flowing.studiot said:First forget capacitance.
My remarks have been tempered with the fact that I have been trying to address the original question throughout this thread and provide an understandable explanation for Canelec's clear appreciation of the truth and quest for an explanation.I was just wondering why it isn't possible for current to flow from the -ve of one battery to the +ve of another? And why when you measure the voltage between the two, you get zero? The -ve of one battery should still be attracted to the +ve of another I would think.
This is not what I'm saying. The other plate is connected to the other rail of the power supply. Now, before you tell me that I am contradicting myself, consider this:If I connected one plate only of a capacitor to either one terminal of a battery or to one rail of the power supply and left the other plate to 'float'
Well, I suppose you do, even though electrons aren't flowing between the plates. I suppose, since we agree on that, we are as much on the same page as we're going to get.You have a circuit !
Perhaps you would like to elaborate. What charge and What voltage?all conductors have capacitance, defined as C=Q/V,
The theory of displacement current can be pretty heavy. If you like I will post what I consider to be an accessible introduction.I'm on wikipedia now reading about displacement current. Interesting stuff!
Across what? This implies it has at least two terminals.V is the voltage across it.
Applied to what? One of the terminals, both of the terminals somewhere in between?Q is applied to it,
Thread starter | Similar threads | Forum | Replies | Date |
LM393 based battery maintainer question | Power Electronics | 3 | ||
C | charging a 9 volt battery question | Power Electronics | 13 | |
S | Battery & Power question | Power Electronics | 12 | |
Victron Battery Protect teardown and question about the isolation. | General Electronics Chat | 3 | ||
J | Lipo battery question | Technical Repair | 2 |
