The Electric field is conservative. This means that integrals are path independant. So any path will lead to the same result.
You don't integrate the field directly. You perform the integral for the work done in moving a (unit) charge from point A to point B.
The electric field (I prefer to call it a potential field) has an origin. this is normally used as our point of reference, common or ground point or what you will.
Somewhere back along there was another thread about all this, I will try to dig it out.
The thing to take away is that 'voltages' are voltage differences between two points or across a component. There is no such thing as absolute voltage.
