Battery powered LED project
Discussion in 'The Projects Forum' started by TexAvery, Jul 12, 2013.
  1. TexAvery
    Oct 7, 2009
    58
    Hello everyone!
    I have a parking meter project that will require 40 to 60 5mm LEDs that need to be battery powered for 30 days, but only at night.
    LEDs can be any color but red.
    I am thinking a Joule Thief circuit with a darkness sensor (photo diode)?
    The challenge is I only have two 1"x1.5"x4" space for the battery/batteries.
    Yes, this would be a paying project.
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    No solar power or recharging?
    I think if you do the math for that much battery volume, and assume the energy density of a modern Li-ion battery, it cannot be done. I could be wrong but that's my gut hunch.
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Lets do some math.
    40 LEDs (the minimum described) x 10mA = 400mA.
    30 nights of runtime is 12x30 = 360Hrs
    That's .4 * 360 = 144Ah
  4. Bernard
    Aug 7, 2008
    4,237
    414
    Decimal point slipped, try 14.4 Ah; still a big battery.
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Opps missed that, thanks.
  6. Bernard
    Aug 7, 2008
    4,237
    414
    Two genuine NiMH D's & bright yellow LED's would come close.
  7. Bernard
    Aug 7, 2008
    4,237
    414
    There is a post for, on @ night, with optional flasher, output would need beefing up.
  8. John P
    Oct 14, 2008
    1,638
    225
    I think that under conditions of subdued ambient light, 10mA would be pretty generous. You might be able to run small white LEDs with 1mA, but it depends on whether you want to create something visible, or actually light up the area around the meter. Could there be some interaction with a user, where if someone were actually near it, the lights would become brighter, or more of them would come on?
    Still, I also think it's ambitious in terms of battery size versus the amount of energy to be delivered.
  9. wayneh
    Sep 9, 2010
    12,379
    3,232
    I think the calculation must be done on power.
    Let's see, 40 LEDs at 10mA and 3Vf equals 1.2 watts. Total for 30 nights is 432 watt-hours. Given circuit losses and such, let's say we need 500 W•hr in the battery.
    Battery volume given is 6 cubic inches or 0.098L. State of the art Li-ion batteries are at 800Whr/L, or just 78 W-hr in the given space. And that's assuming no space for anything but battery guts.
    No can do.
    Flashing and running for much shorter hours would help.
  10. TexAvery
    Oct 7, 2009
    58
    I can fit four 4000mAH 3.7V Li-ion batteries if that helps.
    The LEDs are not for lighting... more for visible effect , so 10mA will work.
    Adding a PIR sensor for interaction would be a bonus!
    Great idea John P ...Interaction with a user, where if someone were actually near it, the lights would become brighter, or more of them would come on is exactly what the job calls for.
  11. wayneh
    Sep 9, 2010
    12,379
    3,232
    That's 59 W-hrs of energy (assuming steady battery voltage, which it isn't).
    You need strategies to dim or turn off the LEDs to save power. There's no way around it. Full-on while dark isn't going to work.
    Flashing at 2-5mA with a 10% duty cycle when nothing is detected by the PIR would save an enormous amount of battery. With multiple flashing strings instead of all at once, you could have a more pleasant effect, perhaps. Goose up the current and the duty cycle when the PIR sees an audience.
  12. John P
    Oct 14, 2008
    1,638
    225
    I was recently visiting a shelter for hikers on the Appalachian Trail which is actually a small house, with beds upstairs. They had battery-powered lights on the stairs, each of which was a bank of white LEDs (maybe 9 of them, or 12, in a rectangular pattern) and there was a motion sensor which made the lights come on when anyone was on the stairs. I don't know how much power it takes to run the motion sensors, but I assume not very much. I expect the lights were just purchased at Home Depot or somewhere, not specially designed.
  13. TexAvery
    Oct 7, 2009
    58
    OK~ I have found more space for batteries, about the volume of four 9v batteries in the parking meter. Let's reduce the number of LEDs to 20 and add PIR interaction so the LEDs are on standby mode (dim) with no movement.
    Is this possible?
  14. wayneh
    Sep 9, 2010
    12,379
    3,232
    Yes, I think so. You need a few basic functions.
    First, use PWM control over your LED brightness. It's more efficient than other methods (e.g. linear control over current) that waste as heat the energy not used by the LEDs. Think about what you want the "quiet time" effect to be. You could have a dim steady glow (fast PWM with very low duty) or a flashing bright blip every few seconds (slow PWM with very low duty cycle.
    Second, you'll need a way to control the PWM duty cycle when the PIR triggers. I'm not familiar with these devices so someone else needs to help here. I think you want full-on (100% duty cycle) for the "awake" status?
    Third, you want the whole thing to do nothing unless it's dark out, right?
  15. TexAvery
    Oct 7, 2009
    58
    Correct LEDs only function during night time.
  16. TexAvery
    Oct 7, 2009
    58
  17. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    That's still 384 hrs of runtime a month. How bright do you need them? Might help if you described what its purpose is.
  18. TexAvery
    Oct 7, 2009
    58
    It will be a functioning single head Parking Meter that will have 20 holes drilled in the enclosure with recessed LEDs that light up at night to attract attention. To save power the LEDs can be dim/blink/fade (ON)-(OFF) whatever. When motion is detected the LEDs get brighter/change effect to give a "AWAKE" indication. Every month the money is collected the attendant can change the batteries.
  19. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    We have all sorts of parking tag meters here in Toronto, Canada. They'll all solar powered and some include RF telemetry. No batteries to replace which would be a pain in the... No reason it could't be shrunk down to a single head unit.
    Why aren't you using solar to charge the cells, gotta have plenty of sunlight in Texas.
  20. Bernard
    Aug 7, 2008
    4,237
    414
    Thr R-S PIR has a hemispherical IR lens, about 7/8 in dia.;is there cpace for it?
