Battery pack switching Series to Parallel
Discussion in 'The Projects Forum' started by Dollarday, Oct 10, 2012.
  1. Dollarday
    Jan 25, 2012
    32
    thread removed
  2. NFA Fabrication
    Member
    Aug 12, 2012
    104
    What are you using these batteries in? Is it an RC vehicle/plane? The way RC lithium packs come, you would need to undo some wiring internally in the battery to make this work. Trying to picture what you're are doing exactly, so I can picture the most logical method of doing this.
  3. Sensacell
    Jun 19, 2012
    1,184
    277
    Looking at your diagram with the simple switches, in 'parallel' configuration, only one battery is in circuit, the top two are not connected on the GND side?
    The 'series' one works, but the 'A' switches are redundant? two each are in parallel?
    You need to re-think this a bit.
