Hi
I have been trying to build a DIY dew heater for my DSLR camera with a 12v battery source. I have been using nichrome wire, and it was working great with only 4 AA batteries, but when I upped it to 8 AA batteries for more heat, the wire heated nicely but the battery pack started to overheat about 10 minutes in. Is there any way I can mitigate it overheating? I tried adding a resistor on the negative side, but it caused the strip not to heat up at all.
Thank you
Thank you
