Battery overcharging?
Discussion in 'The Projects Forum' started by timotb, Oct 31, 2009.
  1. timotb
    Oct 31, 2009
    5
    Im trying to find out if I can keep my "Todd model PC30" charger continuously connected to my deep cycle battery. I cant ask Todd from Tucson AZ, because they are out of business. Of course I’m concerned about overcharges, but wonder if this charger which touts, "provided with integral protection against overloads," will trickle and float?
    It is used in a cabin where I want to keep a 12volt battery system working with intermittent 120volt grid power.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you ruled out the use of an off-the-shelf solution like a UPS (Uninterruptible Power Supply)?
    hgmjr
  3. timotb
    Oct 31, 2009
    5
    I havent ruled out anything. I have the battery and the charger and would like to see that work if possible and keep it simple
    I should point out that the cabin only runs a 12 volt alarm and notification. Neither require much electric beyond a simple 12 volt battery. I will study the Uninterruptible Power Supply concept.
  4. Smoke_Maker
    Sep 24, 2007
    126
    15
    The best way is to test the Todd charger profile with a volt meter, connect the charger to the battery and take a reading every 15 minutes. When the battery reaches full charge it should drop back to float charge.
    http://www.batteryuniversity.com/
    Better yet did you google "Todd charger"
  5. timotb
    Oct 31, 2009
    5
    Voltage with the charger attached is 13.07 volts.....steady Is this defined as a "float charge?"
    Shouldn't I be concerned with Amperage as well? If I did the amperage test correct I connected the meter in-line across the positive side, set the meter for 200mA, then touched the lead to battery terminal to read 21.1, also steady.
    Yes...I have been goggling info on the Todd chargers with little useful info coming up...and thanks for the URL on batteryuniversity.com... I might be able to answer my own question in few minutes.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    After reading this: http://www.mrsharkey.com/forum/vwtp.php?t=707
    I'd heartily recommending throwing the Todd charger away, or use it for project parts. If you try to use it in a remote cabin, it's likely your cabin will be a pile of ashes on a future visit.
  7. timotb
    Oct 31, 2009
    5
  8. MaxSmoke
    Oct 29, 2009
    35
    I use a Ctek charger for my motorcycle, I have found them to be very good. The charger can charge my Odyssey dry lead acid battery (Absorbed Glass Mat - I think), which most chargers cannot charge, simply because most chargers do not have the correct charge characteristic for the Odyssey batteries. Ctek may not be what you are looking for, but here is the link to their website ...
    Ctek Battery Chargers
    The other point to remember when charging lead acid batteries is the requirement for adequate ventilation. The amount of gas release varies with lead acid battery technology, but should be considered.
  9. Smoke_Maker
    Sep 24, 2007
    126
    15
    I'm not sure about that Harbor Fright charger, you get what you pay for. The marine industry is a much better way to go, it's going to cost more but it will last longer and be nicer to your batteries. Just be careful what you connect to you battery or you could be committing batticide.
  10. timotb
    Oct 31, 2009
    5
    Thats what Im debating at the moment. Is Harborfreight 99857 really an improvement over my Todd Charger.
    Ill have to look at some marine chargers.
