I have a driller that works with rechargeable batteries, which have almost failed, and I am not interested in replacing them.
I thought to replace the batteries with a circuit which will be able to supply the driller with the needed current and voltage using a transformer and a certain circuitry. What I don`t know, is how to convert the transformer output to 18V and ~5A (which was the batteries output), while using a transformer that can output less than 5A.
Hope this is clear enough. Thank you!!
