Battery Low
Discussion in 'General Electronics Chat' started by dogstail, Aug 5, 2008.
  1. dogstail
    May 8, 2008
    10
    I am looking for any idea's / circuits on a battery low indicator the battery will only be 3v need the indicator to activate at 2.5v. Can any one help thanks.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Do you need it to light an LED or just give a voltage level? A simple op am with a couple of resistors and diodes would do the latter just fine.
  3. dogstail
    May 8, 2008
    10
    Just looking to light up an LED
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, it gets a bit tricky, but is doable. The problem is the voltage needed to light up the LED. Older LEDs use less dropping voltage, so I'll assume that. Someone else may come up with something better, but I'll see what I can draw up in a bit.
    OK, I've never built this, but I think it should work. I was aiming for as low power as possible.
  5. AchMED
    Aug 5, 2008
    41
  6. KMoffett
    Dec 19, 2007
    2,584
    234
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Can either one of those drive an LED?
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    The MAX8211 should, if his battery cutoff is 2.5v. Its sink current is 4mA (min) and output saturation is 0.17v (typical...I was wrong earlier...0.4v Max)...that leaves at least 2.1v for a high brightness red LED and current limiting resistor.
    Ken
  9. AchMED
    Aug 5, 2008
    41
    It can swing to Vol+0.4 Vcc worst case. They spec 0.8mA for a 3V rail. More then enough to drive a LED. I usually only use 20 to 30 uA.
    Ive never tested it down to that low a voltage though but according to the datasheet it is doable.
