Battery Life for Changing Loads
craigfoo
Joined May 16, 2013
22
I'm trying to figure out how long my battery would last in these conditions:
I have a 3Ah battery and I need to run a sequence. The sequence goes like this:
The maximum draw would be 2 amps.
0 secs: 1 amp draw
2 secs: 2 amp draw
4 secs: 2 amp draw
6 secs: 2 amp draw
8 secs: 2 amp draw
10 secs: 2 amp draw
12 secs: 1 amp draw
14 secs: 0 amp draw
20 secs: repeat sequence
If I were to take this sequence and graph it out, I would think I could take the area of the curve and get Amp-Seconds and do my calculation from there or am I way off base?
#12
Joined Nov 30, 2010
18,224
It really is that simple to find the accumulation of amp-hours.
Then you consider whether you want to run your battery dead before recharging it. Most batteries wear out a lot quicker when run all the way empty between recharges.
craigfoo
Joined May 16, 2013
22
Ok, I thought I was losing it.
So that's 24 Amp-Secs for a cycle, 3 cycles per min which gives me 72 Amp-Secs for a 1 min run time.
It would be 72 Amp-Secs/3600 Secs to get 0.02 Amp-Hours. If I wanted to know how long it would take to only run my battery down to half, where do I go from here?
#12
Joined Nov 30, 2010
18,224
1.5 amp hours divided by .02 amp hours = 75 minutes at 3 cycles per minute...if I didn't slip a digit.
#12
Joined Nov 30, 2010
18,224
72 amp seconds per minute.
72 amp seconds x hour/3600 seconds = .02 amp hours per minute of use
Half the battery capacity is 1.5 amp hours.
1.5 amp hours x 1 minute of use/.02 amp hours = 75 minutes of use
