dear all,
i have connected two batteries in parallel with constant 20 amps dc load. batteries are 155ah/12vdc and brand is powersafe. the problem is when i measured the load through clamp meter then only first battery shows as taking the load. and second battery does not show any load. i was thinking that may b this is just because of the second battery not connected well but when i switched off first battery fuse then load was shifted to 2nd battery. and also 2nd battery bank take charging 5 amps all time even when first battery reached fully charge level. my friend yold me that he is facing also same problem. please tell me what is the reason behind this...thanks
