Battery Internal Resistance
Discussion in 'General Electronics Chat' started by Malcolm Sanders, Jun 21, 2014.
  1. Malcolm Sanders
    Jun 21, 2014
    A battery as a source is often represented by its O/C voltage in series with its internal resistance. When it is being charged can it be represented in the same manner with the same IR or does the internal resistance change when it is being charged??
  2. MrCarlos
    Jan 2, 2010
    400
    134
    Hi Malcolm Sanders
    If the battery is half loaded, has a lower impedance* than when it is fully charged.
    So the impedance* changes as you go charging.
    But if it is loaded by means of a current regulator. that is another roll.
    * internal resistance
  3. crutschow
    Mar 14, 2008
    13,505
    3,376
    The battery apparent internal resistance does change some with the state of charge, going down as the charge goes up, but is basically the same whether it is being charged or discharged (for a given state of charge).
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
