Battery information
Discussion in 'General Electronics Chat' started by dustiin, Jan 23, 2010.
  1. dustiin
    Jan 13, 2010
    60
    Probably some of the most basic questions you guys could think of, but I'm not showing any results on google or here.
    it's a 12V 5AH SLA battery.
    It says
    Type |Voltage regulation|initial current|
    Stand-by-use| 13.5v-13.8v | No limit
    Cycle Use | 14.6v-150.v | 1.5A max
    What does all this mean?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I've re-formatted your text a bit; if you use the [ CODE] [ /CODE] blocks (no spaces) around column-sensitive text, the board won't goof up the formatting. Compose in Notepad beforehand.
    Code ( (Unknown Language)):
    1.
    2. Type         | Voltage regulation |initial current|
    3. -------------+--------------------+---------------+
    4. Stand-by-use |  13.5v-13.8v       | No limit
    5. Cycle Use    |  14.6v-15.0v       | 1.5A max
    6.
    Basically, it means that your battery can be float-charged at 13.5v to 13.8v without a current limiter when it's charged up.
    If it's been discharged, it should be charged up to 14.6v to 15v at a 1.5A maximum current for the charging rate. Then you float charge it at 13.5v-13.8v to keep it ready for use.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    1. Means that you can hook a discharged battery to a constant-voltage power supply set to 13.5 to 13.8V for ever. You do not have to use any current limiting, the battery will charge slowly, and then be "floated". This will not damage the battery. This is not the fastest way to recharge the battery, but it will eventually get it recharged...
    2. Means that you can hook a discharged battery to a constant voltage power supply set to 14.6V to 15.0V, but the supply has to be current-limited to 1.5A max. When first connected, the battery will pull-down the power supply's voltage (due to the supply being current-limited). As the battery accumulates charge, the voltage will come up the set voltage (14.6 to 15V), and the current into the battery will begin to decrease downward from 1.5A. The specified current-limit is to prevent the battery heating excessively. The "Cycle Use" implies that this cycle should be terminated when the battery charging current drops to a small value, like 10% of the 1.5A limit (150mA), at which point the supply voltage should be set to (1), above... This recharges a battery much faster than (1), above.
    There are microprocessor-controlled chargers that mechanize the above algorithm. This is called a three-step charging algorithm (initially current-limited, then voltage limited, current drops, revert to lower float-voltage). See Figure 2 in this document.
  4. dustiin
    Jan 13, 2010
    60
    I see I see. If I hook the battery up to anything less then 12volts it will not charge right?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    In order to completely charge the battery, you'll need to have at least 13.5v as a source.
